Feature |
Product |
Release introduced |
Egress port shaper |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
Fabric Engine 8.10 |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Ingress policer and port rate limiter |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.5 |
5520 Series |
VOSS 8.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.5 |
VSP 7400 Series |
VOSS 8.5 |
QoS ingress port-based rate limiter |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
Not Supported |
5720 Series |
Not Supported |
7520 Series |
Not Supported |
7720 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
Not Supported |
Ingress policer and port rate limiter functionality handles congestion, meters traffic, and takes action based on the ACL filter rules. A policer can be attached directly to an ACL ACE entry to perform flow-based rate limiting. You can configure the service rate and peak rate. All traffic that qualifies for a filter is metered. Every packet that exceeds the service rate is marked as yellow, and every packet that exceeds the peak rate is marked as red and drops. The line rate of the port is the maximum rate that you can configure.
The following section describes operational considerations for ingress policer and port rate limiter functionality:
If you configure ingress policer/port rate limiter and QoS ingress port-based rate limiter on the VSP 4900 Series, and a flow matches both of them, then green marked packets can be dropped.
IPv4 policer statistics for red, yellow, and green packets and bytes are available on VSP 7400 Series.
Only IPv4 policer statistics for red packets and bytes are available on VSP 4900 Series. Yellow and green packet counters are not supported on VSP 4900 Series.
Egress port (outPort) interface is not supported.
Policers are not supported on IPv6 ACLs.
Supports QoS ACEs only.
You can configure the default action policer within an ACL for permit action mode only.
Drop action mode is not supported.
monitor-dst-ports, monitor-dst-mlt, or monitor-isid-offset actions are supported. All traffic received is mirrored.
The filter with policer and redirect-next-hop actions redirect only the traffic that passes the policer (if the stream is 100 Mbps, and the policer peak-rate is 50 Mbps, only 50 Mbps is redirected).
If ACL type is inPort, do not configure Qos port limiter on any of the ports that are part of ACL.
If ACL type is inVlan, do not configure Qos port limiter on ports that are part of any VLAN in the ACL.
If ACL type is inVsn, do not configure Qos port limiter on ports that are part of any VSN in the ACL.
